Editing Metadata in Pro
1372
01-12-2024 03:27 PM
ShareUser
Esri Community Manager
I'm trying to write ISO-compliant metadata for a feature class in Arc Pro and working on filling in entity and attribute information for field-level metadata.  In ArcCatalog 10, the fields would automatically import with the field name and alias information.  Is this capability missing from Pro or is there another way to load the attribute information?
ShareUser
Glad it's working now. In case someone needs it "Synchronize" is on the Metadata tab when Catalog View is open.
ShareUser
Hello @DanJanes,
Have you changed metadata style under ArcGIS PRO Options/Metadata?
As you can see from the attachments (in v3.0.2) it gets the name/alias correctly and automatically.
Regards,
ShareUser
I had tried changing the metadata style several times with no success.  However, your response caused me to go back and look again.   After clicking on "Synchronize" the fields now appear.
ShareUser
Hi!
How did you proceed to edit/customize metadata style?
Is there a way to edit/add tags in existing styles, like edit/add tags i.e ISO19115 and then use this in a organization later?
ShareUser
