Which tools is used to create migratory flux map in ArcGIS?
2950
06-06-2016 02:03 AM
MamadouDiabate
New Contributor II
I am willing to design a migratory map using ArcGIS but I really do not have an idea about the tool to use.
I have a table with the data regarding the number from a departure zone to an arrive zone.
Tags (3)
DanPatterson_Retired
More importantly, what data do you have and what form is it in?  Is it point data in featureclass, shapefile or tabular format?
Is it point or polyline or even polygon geometry? Is it for different time periods?
MamadouDiabate
New Contributor II
The data is in tabular format for one period time.
Best Regards,
perhaps you could share a few rows so we can see if there are any spatial coordinates or designators, or from and to information.  Migration implies movement from one location to another, so this information and its form would be useful.
MamadouDiabate
New Contributor II
The table is attached.
Best Regards,
I would stick with a table and explain it... skip the map, it won't add anything.
