Schematic diagram creation
3754
5
09-17-2014 08:05 AM
TimHughes
Hi all!
I am attempting to create a schematic diagram from some water network data (points and lines).
I have created a Geometric Network using the wizard. I then worked through the Schematics tutorial to create a Schematics dataset and import my feature classes.
When I head back to the MXD to Generate a Schematic Diagram, I select all the options in teh form and give the diagram a name, then hit OK and a new Data Frame is created. Inside are all my layers, however, nothing is showing in the data frame.
Have I setup my data incorrectly? Where am I going wrong?
Any help with this is much appreciated!
I have attached the MXD and the FGDB.
Kind regards
Tim
TimothyHales
Esri Notable Contributor
I've moved your post into the Mapping space. You may get a quicker response as the question will be seen by a focused audience instead of the broad GeoNet community. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Timothy
TimHughes
Hi Timothy,
Thank you very much.
I hope I can get a reply form someone out there!
Kind regards
Tim
RickAnderson
Follow the 'quick start' and see if that resolves the issue.
Quick start configuration for Utilities | ArcGIS Resource Center
TimHughes
Hi Rick,
This is how I set up the schematic and all was going fine until the generate Schematic, where it added the layers to a new Data Frame but did not show anything in the frame 😞
Any other ideas?
Thank you for your help so far.
Tim
RickAnderson
What software version are you using?
I just tried it with the data you provided and it worked just fine.  You didn't include your schematic dataset, so I can't see if there was something wrong with it, but starting from scratch it was fine for me.
