Issues with basemap command
2927
7
04-06-2016 10:24 AM
BELHADJMOHAMED
Issues with basemap command: when I click on basemap from  Add data button  it pops up for one second and then disappears. Pease help. I use ArcGIS 10.3.1 Windows 10. Thanks
AdrianWelsh
MVP Honored Contributor
Hi Belhadj,
Just to be clear, are you trying to load a basemap by dropping down the arrow next to Add Data and selecting Add Basemap...?
Can you click on the Add Basemap option? I have Windows 10 and running 10.3.1 and I am not having any issues.
BELHADJMOHAMED
Hi Andrian,
Thanks for your response. Yes that's just what I do: go to Add Data  button and click on  Add Basemap... , the window Add Basemap pops up for just one second and disappear !!! That is my problem
AdrianWelsh
Is it possible that the winder is on another screen (if you have two monitors) or maybe it's behind ArcMap? It's rather odd that it would disappear so quick.
BELHADJMOHAMED
Here is a short video I made to visualize this kind of strange issue.
AdrianWelsh
Wow, that is weird. Has this happened before? Is this a fresh install of ArcGIS? Tell me about the history of this.  (and thanks for sharing the video, that is helpful to see).
BELHADJMOHAMED
This  version  is 10.3.1 as I mentionned  above: that basemap pane never works for me. and I have an other laptop with with windows 7 and ArcGIS 10.2.2 the same issues happens !!! so I try adding data from ArcGIS online it works fine indeed everything works as I expect except for basemap
AdrianWelsh
Wow, that is even more interesting that two separate machines with different OS's and GIS versions behave the same way. Where are you located? I would doubt this has anything to do with it but there has to be some common thread here.
Maybe try upgrading to 10.4? I don't know if that will help but maybe it couldn't hurt?
