Is there a way to change the drawing order of an extent indicator?
1811
02-23-2018 09:11 AM
AlastairSherren
I have two inset maps (contained within two data frames) within my main data frame.  I am displaying point data with labels in the main data frame and some of these labels and point features are obscured by the frame of the extent indicators: is there a way to draw the extent indicators below the point features and lables (i.e send the extent indicators to the back)?
DanPatterson_Retired
Did you try reordering them in the table of contents?
http://pro.arcgis.com/en/pro-app/help/layouts/extent-indicators.htm at least suggested in PRO, so give it a whirl if an equivalent exists in Map
AbdullahAnter
Occasional Contributor III
I think there no way to change the drawing order of an extent indicator.
but you can draw a hollow polygon with the extent of your data frame after you finish layout,then reorder it in TOC to get your the points above . and don't use pan tool after that.
PeterSmith3
New Contributor III
I've had a similar problem. My solution, in Pro, was to give the extent indictor a coloured fill, set colour transparency to 50% and remove the outline colour.
Map detail, which clashes with the extent indicator, will then show through.
You could try the same with your outline transparency.
AlastairSherren
Hi Peter, thanks for the advice.  This sounds like a good workaround.
