Export to .ai . eps
3679
12
08-20-2014 06:00 AM
JohannesBierer
Is there a possibility to export in this format with the availability for editing the layer symbology in a graphic software?
Normal export to .ai doesn't work?
WilliamMcLay
Wow, never heard that one before! Windows should use the fonts that you have loaded into your system, and publish them to the pdf file. I would eliminate any "English" fonts in the map, which might include any point symbols as they may also be a "font". Make a copy of your original map and do the testing on the copy.
MartinPrinz
Have you applied any transparencies?
JohannesBierer
I'm also the illustrator guy?
