draw tracks from file of 4 colums each 2 columns represent a point
803
07-25-2013 05:44 AM
suhadbehadili
hi
I need to draw track composite of pair points i.e. the track built from multi independent edges each edge from paire points
DanLee
by Esri Regular Contributor
I am not sure if I understand you correctly, but it sounds like you have a table containing x1, y1, x2, and y2. If that is the case, you can try the XY To Line tool:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0017000000tv000000
Hope that helps.
