Contour Interval 40m for Topographic Map 100K
1227
06-24-2021 11:41 PM
chhayvanchha
New Contributor III
Dear All,
I've found that most Topographic Map 100K, its contour interval is 40m. Does anyone know what are the reasons that specific interval is used ?
Thank you in advance !
Waffle_House
Occasional Contributor II
Link?
chhayvanchha
New Contributor III
Sorry I have no idea what you mean, can you say again?
JayantaPoddar
MVP Esteemed Contributor
I am not a topography expert, but I believe one of the prime factors for deciding the contour interval is the scale of the map. A smaller scale map will have lower number of contours (to avoid cluttering), thus the contour interval will be higher between two contour lines. A larger scale map can have higher number of contour lines (also depends on the topography/relief of the terrain), thus the contour interval can be smaller between two lines.
e.g. I can see some topographical maps of Cambodia (Scale 1:50,000) where contour interval is 20 meters.
*The organization (usually the National Mapping Agency) that prepares the topographical maps, decides what is the best suited contour interval for a map at a particular scale.
Think Location
chhayvanchha
New Contributor III
Thank you so much
