Colours in ArcGIS 10.2
3593
7
02-27-2015 06:27 PM
ShyamanthaSubasinghe
New Contributor III
I am using ArcGIS 10.2 and my operating system is 10.2. My colours to change the symbols are very limited. Following figure shows the nature. Can I change these colours to normal colours exists in ArcGIS?
New Contributor III
my operating system is windows 8
DanPatterson_Retired
MVP Esteemed Contributor
Press on more colors ... the colours have nothing to do with your operating system, what type of data are you trying to symbolize?
New Contributor III
I want to get the get the colours as following picture?
New Contributor III
It is windows 7 gives normal colour ramp in ArcGIS but it is abnormal in windows 8.
Windows 8
Windows 7
I need to get the colours with their names..i.e. Fores green
AsrujitSengupta
Regular Contributor III
Windows 8.1....no issues as such
DavidBarnes
Occasional Contributor III
It looks like you probably have multiple styles referenced in each of those. Or, you have multiple copies of each color in one style. It's also possible that styles with the same name on different machines have had colors added or removed.
First, check to make sure the same styles are referenced on all OSs. Then try un-referencing all but the ESRI style and your user style. You can do that through the Style Manager under the Customize menu. If you still see the same thing, look into the Colors folder for the referenced styles (expand the folders in the left-hand pane of the Style Manager).
JayantaPoddar
Try repairing ArcGIS Desktop from the setup/control panel.
Jay
Think Location
