Changing Layout View page size?
8673
10-06-2014 11:22 AM
AnthonyBraun
Can you change the layout view page size? Currently, when you enter the layout view, the map space equates to an 8.5 x 11 size page, which is a standard piece of paper. However, I would like to design maps in the layout view in different sizes and export them in that size. For example, I am wanting to design and export maps that are 11 x 17 page size. Is this possible?
KenBuja
MVP Esteemed Contributor
If this is for ArcMap, in the Page and Print Setup dialog (under File), you can set the paper size
ScottDean
New Contributor II
Or use the layout toolbar and switch your layout to one of many canned choices ESRI has provided for you, including 11x17.  You can build your own and save them into your personal directory (C:\Users\YOURUSERNAME\AppData\Roaming\ESRI\Desktop10.0\ArcMap\Templates) and switch to them at any time.  You still have to properly setup your page/print options as mentioned above.
