ArcGIS Pro editing - Features not appearing
683
01-20-2020 07:14 AM
ChrisShaffer
New Contributor II
So, I'm working in ArcGIS Pro 2.4.3 on Windows 10. I create a new geodatabase feature class, add it to the map, and begin editing. When I left-click to add a point feature, a record gets added to the attribute table, but the features doesn't appear on the map. It fails to appear when zooming or moving the map. The only way I can get it to appear is to save edits and then zoom/move the map. Anyone else experience this? It happens with lines and polygons too. The coordinate system for the map, feature class, and image I'm using for a basemap are all GCS WGS 1984. There are no definitions queries in the feature class. Any help would be much appreciated!
MattBeal
New Contributor III
Did you ever get a solution for this? I am having this exact same issue.
CarolineMazo1
I'm also experiencing this issue - would like to know if either of you came across a solution.
JohannesMitterer
Same here with ArcGIS Pro 2.5.2. Interestingly, erroneous behaviour does not appear every time I manipulate features within a .aprx-Document (all elements are feature classes within a GDB):
I create and load Feature Classes using Python and manipulate them in ArcGIS Pro. Until now it worked perfectly with different documents. In the recent document, I have the above-described problems: Edits are not shown until Edits are saved and zoom-in/-out.
- Restart PC: no solution
- Restart ArcGIS Pro: no solution
- Save the same document using a different path: no solution
