Issue with a date input component
338
7
10-08-2020 12:48 AM
MatejVrtich
picking a date field in a Filter renders a date input component which keeps changing a selected date automatically after the date input component appears. Selecting a date is impossible.
The same issue occurs in a date input component used in a UI used to set a time extent for a map.
Tested in last versions of Chrome, Firefox and Edge.
Attaching a screen recording.
Matej
RussellRoberts1
Esri Frequent Contributor
We have a repro case now, it looks to be related to the system date of the computer when it is set to a specific region. Hope to have it fixed in the next update.
RussellRoberts1
Can you share the map and layer? I can't reproduce this. thanks!
MatejVrtich
Hi Russell Roberts‌,
I can reproduce it on any data with a date field, e.g https://www.arcgis.com/apps/mapviewer/index.html?layers=d957997ccee7408287a963600a77f61f. Attaching a new screen recording of this layer.
It might be related to a locales, as I use Czech locales.
I tried to switch the locales to English using OS/Windows and Browser/Chrome settings, but no difference.
I can see the same issue in a date input component coming from https://esri.github.io/calcite-components/?path=/story/components-date--simple and it seems that Map Viewer Beta is using the Calcite components.
Matej
RussellRoberts1
Yup I am not seeing this with your sample map either. Can you try clearing your cache and testing again?
MatejVrtich
Clearing the cache doesn't work either.
RussellRoberts1
MatejVrtich
Thanks a lot for your support.
Looking forward to the next update.
NaokoKISHIMOTO
We have the same problem. The following is our test results. JFYI.
OSLocaleBrowserMap Viewer Beta UIResult
EnglishJapaneseJapaneseJapaneseNOT repro
JapaneseEnglishEnglishEnglishRepro
