Cannot resize or move a popup still?
241
11-20-2019 01:25 PM
Highlighted
Frequent Contributor II
Is the ability to resize and move a pop going to finally come?  Every other mapping software seems to have it so it always seemed weird to not have it for this many years.
I saw a demo that someone wrote a geocortex app where you could rezise, move, turn on and off a call out arrow, among other stuff.  Just the one guy programmed it so I think it should be pretty easy.
Also seeing the popup says "too many fields to display".  Is there some limit?
thanks
Highlighted
Esri Frequent Contributor
Hi Doug,
Thanks for your feedback. We have made some updates to pop-ups, providing the ability to dock them to the side and expand to encompass some data. Check out Peter's blog https://community.esri.com/community/arcgis-ideas/blog/2019/11/20/your-ideas-in-map-viewer-beta?sr=s...‌ for a more information about the idea that was partially implemented about this.
Could you share a link to your web map so we can look into the too many fields error in more detail?
-Kelly
Reply
Highlighted
The service is behind a government firewall so I cannot.   Here are some screen shots.
When I first load a layer with many fields (141) the Beta map viewer does not display all the fields:
I can open the settings in the pop-up for the attributes and Select All the attributes.  It seems to work, and all the attributes show in the pop-up. But the message saying "some will not be displayed" still shows up.
Reply
Highlighted
The single biggest negative feedback that we get from our users of AGO based apps, using a web map, is that they want to move the popup.  The capability is there in the JSAPI and most of Esri's competitors do it already.  Docking the popup is a start but please make popups movable where ever on the map the user would like to interactively place them.
