Location (single symbol) object label
70
01-21-2021 06:31 AM
BryanHemmer
Occasional Contributor III
I really could not figure out a better title but basically my question is if there is a way to actual label your symbol when using single symbol symbology? You can do this in Pro and it'll carryover into AGOL and your web maps but I can't seem to do this once it has been published. Before someone suggests just renaming the layer I know this already and it does not look professional so that will not work.
Here is an example of what I am talking about. The first item, Nonnative bush honeysuckle, the point was labeled in Pro and it carried over. The second, Invasives - Michigan and Minnesota, was made by combining two point layers. I want to actually have a name for that point in my legend.
