Layer error when sharing from ArcGIS
90
01-22-2021 09:19 AM
AZucker
My storymap has trouble pulling street and place layers from my original map, the error message says "can't be read" I added the street and map labels from the color-coded map from ArcGIS. Does anyone know if there's another way to add these layers over my map? The layers seem to be sourced by world transportation.
Link to map:
https://arcg.is/0O0Kii
RussellRoberts1
Esri Frequent Contributor
Where did you author this web map? It looks to be an issue with the way it was saved out its missing layertype and a few other properties. If you resave the map in map viewer classic this fixes the web map and the layers will load.
RussellRoberts1
