I frequently need to add a service by URL.
143
04-15-2020 12:49 PM
AlanRea
New Contributor III
Looks like that's not available yet. Will check back with this beta later when that's available. Going back to the "classic" viewer.
BenTurrell
Occasional Contributor III
Hey Alan Rea‌,
You can see the ArcGIS Online Map Viewer Beta Roadmap here:
Looks like adding a URL will be coming Fall 2020.
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
RussellRoberts1
Esri Frequent Contributor
You can also add a layer to the map using the URL parameter for now
example:
?url=https://sampleserver6.arcgisonline.com/arcgis/rest/services/Earthquakes_Since1970/FeatureServer
AlanRea
New Contributor III
Thanks Russell, but I'm not seeing where to enter this URL parameter. The Add Layer dialog seems to only allow entry of a search term. Where can you put in this URL parameter?
Al
BenTurrell
Hey Alan Rea‌,
You can add it to the end of your dashboard url:
Here is my dashboard url (It's set to private so it won't be accessible by you but you can see the url):
https://esriau.maps.arcgis.com/apps/mapviewer/index.html?layers=bcbfe64927574b41b9a5b91cc88bf8cd
At the end of the url you can add another parameter with an ampersand so the above example would look like so with the new part in bold:
https://esriau.maps.arcgis.com/apps/mapviewer/index.html?layers=bcbfe64927574b41b9a5b91cc88bf8cd&url=https://sampleserver6.arcgisonline.com/arcgis/rest/services/Earthquakes_Since1970/FeatureServer
Ben
