How to add map image layers in AGOL map viewer beta?
533
11-26-2019 11:01 AM
LanceKirby2
I don't see the option to add a layer from a URL within the new map viewer. I also can't seem to add map image layers within the map viewer beta. The workaround I used was to add those layers within the old map viewer and then open that map in the beta map viewer. Am I missing something or is that functionality not available?
DouglasCochran
Occasional Contributor II
Note: As a work-around, you can add layers by URL parameters.  See this post for more info and/or the doc. Hope that helps!
DouglasCochran
The current version of Map Viewer Beta does not support adding a layer from a URL at this point.  You can follow the latest updates and capabilities with Map Viewer Beta by viewing the Compatibility Guide which will be updated on a regular basis.
DouglasCochran
