Default to Docked Pop Up?
1107
12-30-2019 12:18 PM
SeanHolmes1
Is there an option to default the pop up docked to the side? We get a lot of feedback that they wish pop ups in arcgis enterprise could be kept to the side. The next logical step would be that it defaults to that behavior. Another great addition would be to be able to move the docked pop up.
RussellRoberts1
Esri Frequent Contributor
Currently the docked popup state is stored locally so once you dock it the app will present all popups in that docked state across maps you open with the Map Viewer Beta. This could evolve into the default behavior and we are looking at feedback on the beta to help with that.
For manually moving the popup there are currently no plans for that at this moment.
Thanks for the feedback!
Russ
SeanHolmes1
Russell,
Thanks for the quick reply! It would be nice to have it as an option for an admin to set for the entire portal. The option could read "default popup docked on side" or "default popup over object" and you pick which one you want the default to be for every map. I'm thinking this could be an option in the map settings inside of the admin portal settings.
KellyGerrow
Thanks for the feedback Sean.
Would all of the users in your organization want to have the same setting for pop ups or would it be something each user would want to control?
-Kelly
