Can't change visible range beyond default values
127
09-02-2020 06:39 AM
EkremCanli2
New Contributor III
I have shared a web map from ArcGIS Pro to AGOL and used the map viewer beta in order to have this nice blending capabilities, but the viewer simply won't let me increase or decrease the set visible range. I can change it to get closer to each other, but I can't increase it beyond States on the left side and City on the right side. Also I can't open the drop down menu when clicking on either States or City.
However, this perfectly works on the classic map viewer:
Tags (1)
RussellRoberts1
Esri Frequent Contributor
Can you share the map and I can take a look.
EkremCanli2
New Contributor III
Russell Roberts Can't pm you, so I've shared the map publicly...it's not sensitive content at all. Does this help you already?
RussellRoberts1
Thanks Ekrem, It looks like you only have tiles only for that range and the scale visibility is restricted to the range that tiles are available.
