Beta Map Viewer: unable to add Tapestry Segmentation to map - search shows zero results
226
03-25-2021 03:08 PM
SusanWinchell-Sweeney1
I teach an introductory GIS class (since the pandemic a year ago, have been using ArcGIS Online exclusively). The college
In anticipation of the new Map Viewer rollout next week, I'm re-writing a lab exercise that uses ESRI's Tapestry as a layer (and does not require any Analysis tools). However, a search in the Living Atlas, brings up 0 results (see image below). When I return to what will soon be the Map Viewer Classic and perform the same search, Tapestry shows up immediately and can be added to the map? (image below as well)Glitch? Gremlins?
Thank you very much!
Susan
Update: by searching ArcGIS Online (not Living Atlas) I can bring up several augmented and/or altered "tapestry" layers, including one called "Segmentation in the US" which extends across the entire United States but it uses 2018 data (not what I need or want).
