I would like to add a hyperlink in a Map Viewer Beta Pop-Up, where there is text that the user clicks on to access the hyperlink. I haven't been able to figure this out although I have tried many variants. The link option in the Map Viewer Beta pop-up lets you enter the URL, but I don't see a way to enter the URL display name (as the link in Ask a Question allows). I tried to edit the link as HTML, but this doesn't work either.
This is what I can create ...
Quarterly Review lists can be found at https://geonames.usgs.gov/apex/f?p=GEONAMES_WEB:REVIEW_LISTS:::::
This is what I want ...
Any suggestions are greatly appreciated. Thank you!
Solved! Go to Solution.
First you will need to write the text "Quarterly.. and then highlight it and click the hyperlink button where you would enter the link. After the link is saved it should look like this when editing the popup link text
Thank you so much for your help!
