Adding Hyperlinks in Map Viewer Beta Pop-Up
543
08-29-2020 12:23 PM
DouglasCaldwell1
I would like to add a hyperlink in a Map Viewer Beta Pop-Up, where there is text that the user clicks on to access the hyperlink. I haven't been able to figure this out although I have tried many variants. The link option in the Map Viewer Beta pop-up lets you enter the URL, but I don't see a way to enter the URL display name (as the link in Ask a Question allows). I tried to edit the link as HTML, but this doesn't work either.
This is what I can create ...
Quarterly Review lists can be found at  https://geonames.usgs.gov/apex/f?p=GEONAMES_WEB:REVIEW_LISTS:::::
This is what I want ...
Quarterly Review Lists
Any suggestions are greatly appreciated. Thank you!
RussellRoberts1
Esri Frequent Contributor
First you will need to write the text "Quarterly.. and then highlight it and click the hyperlink button where you would enter the link. After the link is saved it should look like this when editing the popup link text
RussellRoberts1
DouglasCaldwell1
Thank you so much for your help!
