We want to have a grid interval on our layout with different x and y interval.
In the Format Map Grid we unchecked Automatically adjust, and then in the components tab uncheck sync values and then change the interval, for example to longitude 1 deg and Latitude to 2 degrees. However, the display does not change, not even when refreshing the screen.
If we turn on Sync Values and make a change, for example 3 degrees the display updates.
Any thoughts on this? Are we missing something or is this a bug?
Hi Mike,
This is a bug! Excellent catch, I've logged it for my team to fix as soon as possible. I'm sorry for the trouble this is causing in the meantime.
Cheers,
Aubri
So, is there a workaround for this? Apparently it still is not fixed..
Hello, it has been well over a year. I seem to have the same issue. Has this gone anywhere since MikeHendrick's post?
Thank you
