arcpro grid interval in layout not working when sync values is turned off
879
03-04-2019 09:30 AM
MikeHendricks
We want to have a grid interval on our layout with different x and y interval.
In the Format Map Grid we unchecked Automatically adjust, and then in the components tab uncheck sync values and then change the interval, for example to longitude 1 deg and Latitude to 2 degrees.  However, the display does not change, not even when refreshing the screen.
If we turn on Sync Values and make a change, for example 3 degrees the display updates.
Any thoughts on this?  Are we missing something or is this a bug?
Tags (3)
AubriKinghorn
Hi Mike,
This is a bug! Excellent catch, I've logged it for my team to fix as soon as possible. I'm sorry for the trouble this is causing in the meantime.
Cheers,
Aubri
Cheers,
Aubri
MaryJoWatson
So, is there a workaround for this? Apparently it still is not fixed..
TRD
Hello, it has been well over a year. I seem to have the same issue. Has this gone anywhere since MikeHendrick's post?
Thank you
