Extract Roof Form Tool Issues
501
06-27-2019 01:01 PM
AlexanderVencill1
New Contributor II
I've been trying to run the 3D Basemaps for Local Government deployment solution with our county's Lidar. I've worked through the LOD2 buildings tools and gotten stuck on the ExtractRoofForm tool. It fails attempting to set the first edge. The error says it has an invalid field type. I'm pretty sure all of my inputs are correct. Does anyone know how to solve this issue?
Gert_van_Maren
Hi Alexander,
Which version of the solution template are you using? We just released a new version which should solve the problem you are seeing.
Just open your deployment tool in Pro, search for the solution and you should see an exclamation mark next to it. Click on the solution entry and hit deploy to get the latest version in your org.
Can you please test with this version and if the problem is still, there, please share your data so we can test.
Thanks Gert
AlexanderVencill1
New Contributor II
I redeployed the solution and received the same error message, if you give me your email I can send you the data
thanks
Gert_van_Maren
Hi Alexander,
My email is gvanmaren@esri.com
