project las
263
10-01-2020 04:50 PM
Hi there,
I work with building foortprint and ground contour shp files in Projected Coordinate system WGS_1984_World_Mercator. I also brought a las file of the area but that one is available in the Coordinate system GDA_1994_MGA_Zone_55. Inside the ArcGIS environment, the building polylines, the terrain contours and the las data seem to overlay correctly, however, ArcGIS does the ‘projection on the fly’. While I can use the tool ‘Project’ to change the projected coordinate system of a layer to another, it seems I can’t do the same with las files. The only way I came up with to project the las points to WGS_1984_World_Mercator was to covert las to multipoints, and then add a new field with the points’ height.
Is there a more appropriate way to project las points to another coordinate system. I would also like to export the data as points or coordinates. Is there a tool that exports las files to xyz coordinates?
Thanks!
Cheers,
Maria
Reply
Maria,
You can use the Extract LAS tool to re-project your LAS to a different coordinate system if you set this in the Environments.
Extract LAS—Help | Documentation
Jay
Jay
Washoe County GIS
Maria,
Jay
Jay
Washoe County GIS
Hi Jay,
You are right. It works perfectly. Thank you!
Cheers,
Maria
Reply
Great!
Please mark my solution as "Correct", so that this thread shows up as solved.
Jay
Jay
Washoe County GIS
