i have a lidar data which is already classified . i need to make a city model of this data. can someone illustrate how to do in arc gis map or pro
That specific type of 3d construct is normally the domain of City Engine.
What exactly to you want to create or analyze?
I want to create a 3d city model of building alone
Sent from Yahoo Mail on Android
On Wed, May 30, 2018 at 1:50 PM, Dan Patterson<geonet@esri.com> wrote:
#yiv2516446684 * #yiv2516446684 a #yiv2516446684 body {font-family:Helvetica, Arial, sans-serif;}#yiv2516446684 #yiv2516446684 h1, #yiv2516446684 h2, #yiv2516446684 h3, #yiv2516446684 h4, #yiv2516446684 h5, #yiv2516446684 h6, #yiv2516446684 p, #yiv2516446684 hr {}#yiv2516446684 .yiv2516446684button td {}
GeoNet |
Re: i have a lidar data and open street map building foot prints. how to create a 3d city model in arc gis pro or map?
reply from Dan Patterson in LIDAR Resources - View the full discussion
Reply to this message by replying to this email, or go to the message on GeoNet |
Start a new discussion in LIDAR Resources by email or at GeoNet |
Following Re: i have a lidar data and open street map building foot prints. how to create a 3d city model in arc gis pro or map? in these streams: Inbox |
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
Hello Abinaya,
I would suggest downloading the following for use in ArcGIS Pro to make 3D building from your footprints. If you data is classified or unclassified, you could also extract buildings from the lidar itself. You will need Spatial Analyst and 3D Analyst extensions for this.
http://solutions.arcgis.com/local-government/help/local-government-scenes/
Local Government 3D Basemaps is an ArcGIS Pro project that can be used to author high-quality 3D scenes for your local government. These scenes are organized in different Levels of Detail (LOD) and derived from 2D operational data managed by a department or agency within a local government. Once authored, the 3D scenes are a foundation for 3D workflows and applications; and provide a consistent geographic context across local government departments and agencies.
http://www.arcgis.com/home/item.html?id=06dfb37ca4b94e05bd3507cc4424804f
Here's an example of some lidar extract buildings (Classified for buildings) that was run through the Local Government 3D Basemaps process in a scene layer:
http://www.arcgis.com/home/item.html?id=087a3ad1029946ea81c811bd3f2dbfa3
Check out my blog for how to apply the colors to the buildings.
Arthur Crawford - Esri Content Team
Here's an example with Microsoft Building Footprints and lidar: Scene Viewer
Instructions on what I did are here: http://www.arcgis.com/home/item.html?id=3f3de2298e27408689cb71b92340db7f
or on by blog (search on community.esri.com for Arthur's Lidar).
Here's a recent city done with City of Duluth building footprints, Lidar extracted building footprints and Microsoft Building footprints: http://www.arcgis.com/home/item.html?id=bb3bc86ce2b14f5a99fbb745c93bc828
