join table
879
10-05-2020 04:10 AM
AltinPojani
hi
I need to join  tabel to csv can you help someone please to attach file
ManishPatel
Hi Altin Pojani,
Your question doesnt make any sense? if you can elaborate and explain what you are exactly looking for might help to provide some guidelines.
However, based on quick look it seems you want to find a way to join. Please refer to the technical article How To: Join an Excel spreadsheet (.xls) to a feature class in ArcMap
Hope this helps.
Cheers,
Manish
If this answer solved your question or if you found it helpful please mark it accordingly to help others who have the same question.
Cheers,
Manish
AltinPojani
hi
I have wmts links and i need to import this table the number of home of wmts is the same with the number of csv ....
HeatherSmith
Hi Altin,
To join a table in ArcGIS Online, see this article: https://www.esri.com/arcgis-blog/products/arcgis-online/data-management/add-spreadsheet-data-to-arcg.../
For an example of how to do this in ArcGIS Pro, see the first part of this lesson: Homeless in the Badlands | Learn ArcGIS  and the documentation here: Overview of joins and relates—ArcGIS Pro | Documentation  and here: https://pro.arcgis.com/en/pro-app/tool-reference/data-management/join-field.ht
AltinPojani
in the case when i havet coordinate ...
