i am new to the software and very excited, however, esri does not support helping newcomers very well?? apparently I have the wrong subscription for training past how to install and start the software??
Hi Paul Fausey,
Did you have a look at the online help? ArcGIS Pro | 2D and 3D GIS Mapping Software
There you will also find information on editing:
Editing in ArcGIS Pro—ArcGIS Pro | Documentation
And there is Esri Academy where you can search for the training you need.
Hope this helps to get you started.
BR,
Egge-Jan
Hi Paul,
I recommend this lesson: Get started with ArcGIS Pro | Learn ArcGIS
It sounds like you want to create an empty layer that you will manually add data to. If that's the case, I recommend using map notes. It's the easiest way to make a new layer: Map notes—ArcGIS Pro | Documentation
You may also find these short videos helpful:
Create points from a table—ArcGIS Pro | Documentation
Add data to a project—ArcGIS Pro | Documentation
This article may also help you: Using common GIS data types in ArcGIS Pro.
Thank you,
Heather
