Field calculator to calculate diff (row values) in a single column
2759
5
05-16-2018 05:23 AM
youngpark
I have a column for elevation for a point data set.  I would like to create a new column to show a difference between Row(n) and Row(n+1) values.  well, I assume that the easiest way is calculating in EXCEL (=abs(A1-A2)) then make a join at ArcGIS.  However, I would like to the process with "Field calculator"   Does anyone know how to do it?
Thanks in advance
DanPatterson_Retired
Added to Table Tools for PRO
as a field calculator sequence function
RobertBorchert
Frequent Contributor III
abs([field 1] - [field 2])
youngpark
Hi Robert.
Value comparison in a SINGLE column.
NOT comparing field 1 and field 2.
Learn GIS ... some python?
Could make this into a script or copy and paste into the python window or your python IDE
# (1) specify the table you want to use, with the OBJECTID field and
#     the field you want to get sequential differences for
# (2) convert the table to a numpy array... there is some magic in that we
#     'view' the data as double type (see the vals = line)
# (3) perform the difference, diff, by offsetting and slicing the input values)
# (4) create an output array to put the values in
# (5) 'join' permanently the result (out) to the input using the ExtendTable func
# ---- example below was a quick test to calculate sequential difference in 'Xs'
flds = ['OBJECTID', 'Xs']
pth = r"C:\Your_spaceless_path\Your.gdb\Your_table"
tbl = arcpy.da.TableToNumPyArray(pth, flds)
vals = tbl['Xs'].view(np.float64)
diff = vals[1:] - vals[:-1]  # ---- changeup the function ----
out = np.zeros((tbl.shape[0],), dtype=[('IDs', '<i4'), ('Seq_Diff', '<f8')])
out['IDs'] = tbl['OBJECTID']
out['Seq_Diff'][1:] = diff
arcpy.da.ExtendTable(pth, 'OBJECTID', out, 'IDs')
# ---- Seems like overkill? nope... I just stole the code from a pre-existing
#      snippet, changed the filename, the field of interest and my amazing math function
Obviously study material, but give it a try sometime.
youngpark
Thanks, Dan,
I really appreciate it
