In this lesson, you'll create new numeric fields and populate them with the data from the text fields. You'll learn how to choose a field type and how to calculate fields.
In this lesson, you are a GIS analyst tasked by your organization with improving respiratory health by identifying the areas in your community that would most benefit from increased funding for respiratory health educational programs, at-home air filtration systems, and other interventions to reduce and manage childhood asthma rates. To accomplish this, you will create a social equity index map that ranks each census block group in Lucas County, Ohio, in order of priority, based on 12 of the demographic indicators identified in collaboration with local residents. The resulting map with this index would help decision makers find locations where additional resource allocation would have the highest impact.
In this lesson, you are a resilience planner for Miami-Dade County in Florida looking for ways to address extreme heat in your community. One of several options, or interventions, you will consider is opening cooling centers. Cooling centers are public spaces in the community with air conditioning, cold water, and other amenities that offer protection against the health effects of extreme heat. To meet city goals, you want to understand where cooling centers should be located to support the most vulnerable and historically underserved communities in the county.
In this lesson, you have a layer of building footprints for a neighborhood in Boulder, Colorado, U.S.A. The layer is missing some buildings, so you'll copy and paste features from another layer. You'll learn how to use some of the ArcGIS Pro editing tools, including Paste Special and the Attributes pane.
