New Learn Paths
A Learn Path is sequenced set of resources for learning about a particular topic. Here's a roundup of new paths in the Learn ArcGIS Gallery that have appeared in the last month.
Explore the different types of data you can collect with Survey123.
Explore the different ways you access and use survey results collected with Survey123.
Learn how to build immersive web experiences.
New Learn Lessons
A Learn Lesson is a step-by-step tutorial that uses a real-world scenario to introduce key ArcGIS tools and workflows. Here's a roundup of new lessons in the Learn ArcGIS Gallery that have appeared in the last month.
Every 15 to 30 years, a city is tasked with updating their comprehensive plan. The comprehensive plan is responsible for providing a framework, vision, and goal for the city for the upcoming years. An integral part of a city's comprehensive plan update is to understand current trends in the city. In this lesson, you'll analyze demographic and housing trends as they relate to a comprehensive plan update. Your results will provide insight and context for the general framework of the plan.
Make web maps with projections other than Web Mercator. Build and publish vector tiles from ArcGIS Pro to make a basemap in a chosen projected coordinate system.
