Entering a traverse in ArcGIS Pro does NOT close but entering the same traverse in ArcMap DOES close. Help!
288
12-02-2020 01:26 PM
MatthewBeal
Here are the values  and drawing in ArcPro:
Here is the same thing done in ArcMap:
I hope I'm missing something obvious, but I've been trying for an hour now and can't figure it out. I'll also attach the traverse files from ArcMap and ArcPro.
Reply
jcarlson
The Pro traverse defaults to tangent direction when entering a curve. Try entering your curve bearing as 85-55-13-3 cb.
The "cb" tells Pro that you are entering a chord bearing rather than a tangent.
- Josh Carlson
Kendall County GIS
Reply
jcarlson
PS - You should check out the shortcuts for the Pro traverse, as there are a number of really handy ones. I don't see radial bearings and delta angles often, but being able to quickly and easily incorporate them into my traverse is really great.
https://pro.arcgis.com/en/pro-app/help/editing/enter-a-traverse.htm#GUID-5B9D1444-2C4D-4571-9A28-614...
- Josh Carlson
Kendall County GIS
Reply
