I'm trying to create a parallel utility easement along right-of-ways and really hope not to have to segment ever curve from plat. The attached *.jpeg shows a half-circle curve in a type of cul-de-sac or turn-about. I cannot for the life of me offset that arc without ArcMap crashing...does anyone have any tricks or suggestions? Thanks.
Larry,
There a 2 possible reasons/solutions for this:
-Tim
simplify from an arc to a polyline or try splitting it
I am needing to find a solution to this...it's like Parcel Editor doesn't like these circular curves...the easement parcel was a polygon class and loaded into the fabric....then it broke...there has got to be a way to split this or do something other than trashing the parcel...anyone?
Larry,
-Tim
Again, thank you Tim....changing the sign of the chord length worked. Thus far in my fabric (I mean, how many of these could there be?) I haven't had a curve like this so I wouldn't have imagined that modifying the value for the chord distance was a "thing"....
