Can someone please explain how and when acreage is calculated for the Stated Area field? Our cadastral mapper is experiencing strange behavior with acreages calculated after running the Parcel Remainder task - including more acreage than the original parcel. I ran the same remainder and there was no acreage calculated at all. Do we need to manually maintain that field? I was under the impression that the fabric would handle it.
Jeff Ward
GIS Coordinator
Summit County, Utah
Solved! Go to Solution.
I never liked the wording of "Compiled from Records"... it just seems backwards from what the field actually means. I changed the alias on mine to Compiled from Geometry (or maybe Calculated from Geometry... can't remember exactly).
I am marking this post as the answer since it did answer the original question.
For those keeping score, the undesired results of the remainder procedure when the child parcel departs the parent parcel on a curve was classified as a bug - BUG-000083959. In my support reports the bug is marked as fixed in 10.3.1.
Jeff, the latest 10.3 patch for fabrics, published on Monday also includes this fix:
ArcGIS 10.3 for Desktop Parcel Fabric General Maintenance Patch
Thanks again for reporting the problem.
-Tim
Sweet, downloading now.
