Loading Data into a Parcel Fabric
3912
12-21-2015 08:52 AM
SebastianRoberts
There is a 2011 "Loading Data into a Parcel Fabric" Esri White Paper.  Has this paper ever been updated or does anyone have any info on best practices that have changed since 10.0?
A little background: We've built most of our county from CAD data, but will be loading one city from a file geodatabase polygon FC that will need to have linestrings split into two point lines and true curves created from curves represented as line strings.
DanPatterson_Retired
SebastianRoberts
I found the Migrating Data into the Parcel Fabric Solution recording in the Land Records Meetup
http://www.meetup.com/Esri-Land-Records-Meet-Up/pages/Meeting%27s_Recordings
It is a great overview.  In the recording they mention that you shouldn't use the whitepaper anymore, but instead use the online help that you linked to above.
