The Pro traverse defaults to tangent direction when entering a curve. Try entering your curve bearing as 85-55-13-3 cb.
The "cb" tells Pro that you are entering a chord bearing rather than a tangent.
PS - You should check out the shortcuts for the Pro traverse, as there are a number of really handy ones. I don't see radial bearings and delta angles often, but being able to quickly and easily incorporate them into my traverse is really great.
You can force closure with this shortcut or increase the closure tolerance.
