How to add a new field to Shapefile Feature Table
823
10-15-2023 07:12 PM
jokerjoker
Is there a way to extent the Fields of Shapefile Feature Table, such as adding adding a new Column to the table
I only see how to read
val shapeFileTable = ShapefileFeatureTable(shpPath)
shapeFileTable.load().onSuccess {
val fields = shapeFileTable.fields
fields.forEach {
logj(it.name)
}.onFailure {
logj(it.toString())
RamaChintapalli
Editing of the fields on Shapefile is not supported in Maps SDKs. You can edit so using ArcGIS Pro  to add new fields and read them in Maps SDK.
If you are looking for client side data storage options, you can also try creating mobile geodatabases and define the fields of your choice. Here is a sample to create mobile geodatabases.
Rama
RamaChintapalli
Rama
jokerjoker
thank you
