How do I display map server symbols in legend in Kotlin 200.2
1242
09-15-2023 01:42 PM
klebercj
Below is the function I'm using to create my legend data.  Debugging of the data shows the symbology from the map server is being pulled, but not displayed.  What would I need to do in order to make the symbols display in the legend?
fun showLegendDialog(view: View) {
val dialogView = LayoutInflater.from(this).inflate(R.layout.legend_dialog, null)
val builder = AlertDialog.Builder(this)
.setTitle("Legend")
.setView(dialogView)
.setPositiveButton("Close") { dialog, _ -> dialog.dismiss() }
val dialog = builder.create()
dialog.show()
val legendLayout: LinearLayout = dialogView.findViewById(R.id.legendLayout)
val mapImageLayer = mapView.map?.operationalLayers?.get(0) as? ArcGISMapImageLayer
mapImageLayer?.let {
CoroutineScope(Dispatchers.Main).launch {
val mapServerNameTextView = TextView(this@MainActivity)
mapServerNameTextView.text = it.name
mapServerNameTextView.setTypeface(null, Typeface.BOLD)
mapServerNameTextView.setTextSize(TypedValue.COMPLEX_UNIT_SP, 20f)
legendLayout.addView(mapServerNameTextView)
for (sublayer in it.mapImageSublayers) {
if (sublayer.isVisible) {
val sublayerNameTextView = TextView(this@MainActivity)
sublayerNameTextView.text = " " + sublayer.name
sublayerNameTextView.setTypeface(null, Typeface.BOLD)
sublayerNameTextView.setTextSize(TypedValue.COMPLEX_UNIT_SP, 16f)
legendLayout.addView(sublayerNameTextView)
val legenddata = sublayer.fetchLegendInfos()
for (legendInfo in legenddata.getOrThrow()) {
val legendImageView = ImageView(this@MainActivity)
val symbol = legendInfo.symbol
if (symbol != null) {
legendLayout.addView(legendImageView)
val legendName = legendInfo.name
if (legendName.isNotEmpty()) {
val legendNameTextView = TextView(this@MainActivity)
legendNameTextView.text = " " + legendName
legendLayout.addView(legendNameTextView)
GuntherHeppner
You will need to create a bitmap from your symbol and then pass that to your ImageView. In oder to create a bitmap from your symbol, use one of the Symbol.createSwatch functions.
GuntherHeppner
klebercj
Thank you I was able to use the Symbol.createSwatch functions to display the symbology of the map server I was using.
