Can maps made available offline without a portal item (id)?
772
07-17-2023 06:51 AM
padmalcom
Hi, we load a wms layer (and later a vector tiled layer) to build a Basemap that initializes the map in our android app. Currently, we try to make the map available offline but the error we get says the map must have an item property:
Caused by: com.arcgismaps.exceptions.ArcGISExceptionImpl: message=Illegal state., additionalMessage=Failed to load offline map task.
2023-07-17 15:15:41.259 20654-20654 System.err com.x.mobile.stage W The online map must have an item property which is its online portal item., errorCode=6
We don't operate the portal server and use direct URLs to the service, such as
https://sgx.geodatenzentrum.de/wms_topplus_open?request=GetCapabilities&service=wms
 My question is now: How can I make a map available offline without the portal item?
MarkBockenhauer
Do you want the WMS data to actually display and work when the user is offline?
Or is it something that you want in the map, so that it can work if the user is online?
padmalcom
Hi @MarkBockenhauer, we want the wms layer to show as basemap when the use is offline.
MarkBockenhauer
WMS does not support offline use.   Vector Tile Packages (.vtpk) and Tile Packages (.tpkx) do work well for offline basemap workflows.
