Fastest way to delete a bunch of members in ArcGIS Online
4247
07-27-2020 04:58 PM
FranHarvey2
What is the simplest and fastest way to delete a bunch, 100, members in ArcGIS Online?
EduardoFernandez1
Hello Fran
There is an out of the box way to bulk delete members.
The first challenge you have is that it is not possible to delete members that have content, so, as an AGOL Administrator, you would first have to either delete a member's content or have it moved to another member. Then you can delete that member.
If none of the users have any content then you could create something using the REST API:
Delete User—ArcGIS REST API | ArcGIS for Developers
The workflow would need to get a token first and issue the delete requests as an administrator user:
Implementing App Login | ArcGIS for Developers
Regards Ed
FranHarvey2
Thank you, Ed.  Will give it a try.  Knew about the members content having to be deleted.  Appreciate the info re: REST API and Token.
JoshuaSharp-Heward
Hi Fran, also worth looking at doing this with the API for Python, as it is makes it very easy to automate all sorts of processes in AGOL/Portal. Accessing and managing users | ArcGIS for Developers
You can even quite easily check to see if users have content, and if so reassign to another user etc, which you can see in the examples on the page I linked.
CharlieFitzpatrick
Esri Alum
Hi Fran, the GeoJobe AdminTools, even the free standard version, allows you to do this. You have to choose what is to happen with content and groups, but you can plan that.
First, though, revoke any premium app licenses -- Community Analyst, Pro, etc.Get than done, then take a quick inspection of content and decide what to do, then you can engage the tool more successfully.
