How to get the centroid of a "C" or "U" shape like polygon?
2574
8
09-15-2016 07:15 PM
Joo_PinTan
Anyone know how to get the centroid of a "C", or "U" shape like polygon and the point need to be inside the polygon some where near the centre?
DanPatterson_Retired
in most Arc* products this is referred to as a LabelPoint, so look for some incarnation of that term
ie
The point at which the label is located. The labelPoint is always located within or on a feature.
JoshuaBixby
For the Java API, getLabelPointForPolygon in the GeometryEngine class.
like I said Joshua... they have to look for labelpoint stuff ... grief
JayantaPoddar
MVP Alum
In Feature to Point Tool, choose "INSIDE" as the point location.
Think Location
Joo_PinTan
I need to use ArcGis Runtime SDK for Java API to code it. Feature to point is not available for me.
JayantaPoddar
MVP Alum
Oops... My mistake. Didn't notice the Space where it's posted.
Think Location
did you look for labelpoint or not? it would be in a polygon class or methods section for your api
Joo_PinTan
protected boolean determineCentroid(Geometry polygon, Point centroid) {
  if (polygon.getType() == Geometry.Type.POLYGON) {
    Point tempCentroid;
    //Get centroid of the polygon
    Envelope env = new Envelope();
    polygon.queryEnvelope(env);
    tempCentroid = env.getCenter();
    //If tempCentroid is within the polygon then centroid is valid, else look for nearest vertex
    if (GeometryEngine.within(polygon, tempCentroid, featureServiceTable.getSpatialReference()))
      centroid.setXY(tempCentroid.getX(), tempCentroid.getY());
    else {
      Proximity2DResult proximity2DResult = GeometryEngine.getNearestCoordinate(polygon, tempCentroid, true);
      centroid.setXY(proximity2DResult.getCoordinate().getX(), proximity2DResult.getCoordinate().getY());
    return true;
  return false;
I did something as shown above to look for the centroid of a polygon whereby the centre is empty. Although the result it is not really plotted at the "centre" of the polygon but it did solved my problem.
