ArcGIS Architecture Series: Moving to the Cloud
3825
5
06-07-2019 12:36 PM
AhmadAbdallah
The Architecture Practice team in Professional Services is pleased to announce this new series. The ArcGIS platform is supported on both on-premises or in a cloud environment like Microsoft Azure or Amazon Web Services (AWS). By leveraging these components, you can expose GIS content and capabilities as web services and consume those services in your apps. This enables users to access and apply useful GIS resources in their work.
We will be discussing different cloud related topics that gives you a unique opportunity to align technology with your overall business vision, which in turn can help you grow your business, improve productivity, and reduce costs.
  • Considerations before moving your GIS to the Cloud - To cloud or not to cloud is the question that many organizations are currently facing. While on-premise data center technology is not necessarily on the verge of extinction, cloud computing is an option with many benefits including scalability, agility and cost efficiency.
  • Deploying Desktops in the Cloud - The cloud offers multiple desktop options and  Jeff DeWeese discusses  some high-level guidance as to how and when these technologies should be used.
Note: The contents presented above are recommendations that will typically improve performance for many scenarios. However, in some cases, these recommendations may not produce better performance results, in which case, additional performance testing and system configuration modifications may be needed.
KevinSchulte
Is there any document that explains the licensing within cloud deployments?
JacobBoyle412
Hi Kevin,
There is, please see: https://www.esri.com/content/dam/esrisites/en-us/media/whitepaper/licensing-arcgis-enterprise-deploy...
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
EmmanuelAni
What does Bring Your Own License (BYOL) mean for AWS? Can I use enterprise with just an AWS subscription or do I still need to purchase an Esri license?
JoshuaBixby
BYOL means the same in AWS as it means anywhere else, i.e., you need to bring your own license because it isn't included in the hosting environment cost.
JacobBoyle412
BYOL is exactly that, you need to acquire an Esri license prior to deployment and use that to deploy on AWS.
