Simply put, test data is used to drive a performance or load test by requesting different areas of interest from an ArcGIS Enterprise map service. This spatial parts of the data usually takes the form of a points or bounding boxes (bboxes) and is typically stored a plain text file or in some cases a database.
Previous Community Articles on Load Testing ArcGIS Enterprise with Apache JMeter focused on strategies for building test logic and running the test. The sample projects provided on these blogs included test data in the form of plain text comma separated value (CSV) files that plugged right into the requests. These CSV files contained items like bounding boxes and a corresponding spatial reference to provide the HTTP requests in the test with parameter information. With each iteration of test, the next line of data is read in which is then populated into the request.
For demonstration purposes, this test data worked well for requesting different map scales against services like SampleWorldCities and NaturalEarth. However, those sample test datasets are limited for use with other map services as the pre-generated bounding boxes were created to only ask for areas of interest around the world at a high level. If your organization is working with data at the state, county or city level, you'll want to have test data that focuses on those areas to maximize load test value. In other others, you want test data at a larger map scale and test data cover a specific area of interest.
Generating such data that is specific to your services or your spatial data becomes a critical piece of the process for making a good load test. While composing a few geometries by hand for a simple test is certainly doable, the request signatures are quickly repeated resulting in scalability patterns that are skewed and not realistic. A better test is one that utilizes a large amount of random geometries to push the map service and hardware resource more effectively.
Thankfully, there is a set of recently released testing tools for ArcGIS Pro on GitHub that makes the task of data generation extraordinarily easy.
Once the load-testing-tools project has been downloaded to your machine, place the folder in a directory that is accessible or made accessible by ArcGIS Pro.
For example:
In this ArcGIS Pro project, a polygon feature class (U.S. State of Indiana in pink) has been added to the Map to define a boundary around the area where the bounding boxes for the requests in the test will be generated.
You can launch the Generate Bounding Boxes tool, by navigating the load-testing-tools folder from the ArcGIS Pro Catalog screen. Expand the Load Testing Tools.tbx and double-click on Generate Bounding Boxes. The Geoprocessing screen should populate and look similar to the following:
One of the convenient features about the Generate Bounding Boxes tool is that technically ready to go just by clicking Run! With the default options, it will randomly generate bounding boxes using the current extent of the ArcGIS Pro map.
Note: The default map scales of the Generate Bounding Boxes tool are similar to those of ArcGIS Online but for brevity, only every other scale is listed. You additional map scales are needed, they can be manually added from within the tool.
While this make the data generation really easy, in this example, we are interested in generating boxes inside a particular polygon (State of Indiana). We also want to be very specific on the map scales our test will be using, so we'll want to remove some scales and add others from the tool's interface.
From the Generate Bounding Boxes tool:
Note: Some of the generated bounding boxes may have portions of the their geometry that fall outside the polygon of interest. This is okay.
Note: Depending on your data and it density at the larger scales, it could be advantageous to generate more than 3000 bounding boxes (per scale) in order to "cover more ground". Keep in mind that some load test frameworks may read CSV data into memory and creating extremely large datasets may require more memory from the test client.
Note: The feature class to use as a Polygon Layer for spatial filtering can utilize a Projected Coordinate Systems other than WGS 1984 Web Mercator (auxiliary sphere). However, the generated CSV data will still be projected into bounding boxes that have a WKID of 3857.
With a procedure for generating spatially customized data, you can take the CSV files and import them into an Apache JMeter Test Plan to use in a load test.
The previous testing Articles:
Provided Apache JMeter sample tests that would make good templates to use with your new data and against your map services.
Using the CSV Data Set Config element in JMeter, the new generated test data can be referenced from its path on the file system.
The HTTP Request elements pointing to your map service can then be adjusted to utilize variables such as ${bbox_288895} that reference your generated test data.
Apache JMeter released under the Apache License 2.0. Apache, Apache JMeter, JMeter, the Apache feather, and the Apache JMeter logo are trademarks of the Apache Software Foundation.
