At this point, web maps are easy to use, and quick to make, and many of our Web GIS users are happy to share a link to their ArcGIS Online or Portal Map Viewer and go from there. That being said, it can be argued that almost any web map would benefit from being taken out of the authoring view of the Map Viewer and into a web application better suited to its use case.
This Spotlight Talk looks breaks down some main advantages that Web Application Templates can provide to your organization.
Whether you find yourself a chronic user of the Map Viewer, or are not sure what type of application to make, the bottom line is this: If you want to make cleaner, clearer, and better maps efficiently while reducing costs, web mapping applications contain the tools to help you maximize value with your Web GIS.
Download the PDF version of the presentation from 2018 Esri User’s Conference: Maximize Value with Web Application Templates
