Implementing ArcGIS Blog
Other Boards in This Place
Latest Activity
(181 Posts)
AaronLopez
For evaluating Site performance and quantifying service popularity, System Log Parser (SLP) has several report offerings to conduct ArcGIS Enterprise log analysis. When selecting Analysis Types such as Simple, WithOverviewCharts or Complete, there is an
option called "Add Statistics By User to Report" which will include an additional worksheet called Statistics By User into the generated report. The information on this worksheet includes a statistical summary
of successful Portal member requests (as reported by ArcGIS Enterprise). This can be quite helpful for GIS administrators to understanding who is asking for what.
Sometimes however, the listed User on this worksheet may show the value of "anonymous". For a Site with secured services, this might be a puzzling username to observe. This Community Articles helps explains why this can occur.
Read more...
more
5 0 204
DannyKrouk
This article describes a process for GIS and IT to collaborate to configure F5's BIG-IP to provide access to  an ArcGIS Enterprise deployment.  The goal of the article is share some of the foundational concepts for a "basic" case.  "Basic" does not mean "simple", however.  This configuration objective involves understanding and using many advanced concepts from several different information domains.
Read more...
more
10 11 1,820
AaronLopez
Optimizing the ArcSOC instance availability and utilization for your service is a good strategy for helping users obtain fast response times and lower wait times from their dynamic requests to your Site. It can also benefit server resource utilization like memory as the service is not running a lot of instances that it will never use.
But optimizing the minimum and maximum number of instances for your dedicated services is not a one-time job. Usage patterns of your services can change over time so the task of collecting this information is something that you will want and to revisit periodically as a GIS administrator.
Before diving into how to observe ArcSOC instance activity statistics, let’s review some of the key details of the two ArcSOC-based service types in ArcGIS Server and how they play into this discussion:
  • Dedicated
  • Shared
Table Of Contents
  • ArcSOC Availability and Utilization
  • Dedicated Instance Pool Services
  • Limitations of Shared Instance Pool Services
  • Configured ArcSOC Instance Availability vs Instance Demand
  • ArcGIS Server Service Report
  • Automating the Service Report Collection with Soccer
  • Analyzing the CSV File
  • Final Thoughts
Read more...
more
11 2 2,433
DannyKrouk
GIS Enterprise Reporter now has a companion application “er_compare.exe” that allows you to compare two ArcGIS Enterprise systems.
Read more...
more
4 0 2,577
AaronLopez
Looking for a quick way to summarize the details of all your ArcGIS Enterprise services? If so, then System Log Parser's ServiceDetails Analysis Type is highly recommended. This feature performs a scan of your Site through the REST Admin API and presents the gathered information into a spreadsheet report for easy digestion.
The report is a great resource to find details on your service provider statistics, service configuration info, or data source analysis.
Read more...
more
2 0 1,692
AaronLopez
The System Log Parser (SLP) utility is great for being able to analyze many different "ArcGIS Enterprise" log sources to help quantify the usage of your Site. It is free and includes an easy-to-use graphical user interface (GUI) called SystemLogsGUI.exe. But, did you know it can also be run from the command line via the slp.exe that is included with the download?
Command line capable execution makes a good fit for automation through PowerShell or good old fashioned bat scripts.
The slp.exe executable includes all of the same capabilities. However, you can override many of the limits imposed by the GUI such as: the end time and start time. You can even access features that are not available from the GUI like: searching with specific UTC dates, customizing the name of the report, and enabling the application debug log (for troubleshooting).
Read more...
more
7 3 2,821
DannyKrouk
The GIS Enterprise Reporter provides a wide variety of information about the services in ArcGIS Enterprise.  This article describes the information gathered by GIS Enterprise Reporter and how to understand it.
Read more...
more
6 0 2,475
AaronLopez
Although you are probably familiar with using System Log Parser (SLP) to read logs and help you quantify your ArcGIS Enterprise usage, there is a relatively new feature in this popular, free utility that can make the effort easier and the analysis more powerful.
The new feature, commonly referred to as the Optimized report in System Log Parser, allows you perform log queries of much larger time spans. In addition, it can perform the parsing faster and with tremendous memory savings over the classic analysis types (e.g. Simple, WithOverviewCharts and Complete).
The Optimized option still generates a spreadsheet-based report statistically summarizing the collected log information into key time focused categories.
Read more...
more
3 4 5,832
JeffDeWeese
Resources for planning the virtualization of ArcGIS Pro.
Read more...
more
2 5 2,750
NoahMayer
The Architecture Practice team in Professional Services have been writing articles to assist the community to plan, design and deploy ArcGIS Enterprise. This purpose of this page is to be a single resource to all these blogs and will be updated as new posts are created.
Read more...
more
18 1 4,364
105 Subscribers
