Looking for a quick way to summarize the details of all your ArcGIS Enterprise services? If so, then System Log Parser's ServiceDetails Analysis Type is highly recommended. This feature performs a scan of your Site through the REST Admin API and presents the gathered information into a spreadsheet report for easy digestion.
The report is a great resource to find details on your service provider statistics, service configuration info, or data source analysis.
Note: The ServiceDetails Analysis Type is only available with an ArcGIS Server (Web) log query since it must make use of the REST Admin API
The ServiceDetails Analysis Type is also available from the command-line.
For example:
slp.exe -s https://yourwebadaptor.domain.com/server -u gisadmin -p Myp@ssword -pfl true -validate true -a servicedetails
Bug fixes and new features are always being added to SLP.
The latest version can be found here: System Log Parser (0.12.17.0)
