Ship Detection (SAR) model can not be consumed in ArcGIS Image for ArcGIS Online
1617
11-08-2023 03:36 PM
Yann-EricBoyeau
We successfully used the Ship Detection (SAR) (https://www.arcgis.com/home/item.html?id=705f4c04ac3043be806529047b79abfd) in ArcGIS Pro.
We had no luck in AGOL. It appears the model can not load properly in ArcGIS Online. The model parameters interface turns into an infinite loop (see attached)
As this model takes an additional argument (Water mask), it may be related to this parameter.
Can anyone confirms if there is a bug with this model in AGOL ?
THX
Tags (1)
PriyankaTuteja
Hi @Yann-EricBoyeau  The screenshot attached shows that you are trying to run the tool "Detect Change using Deep Learning". However, the SAR Ship model is supported with Detect Objects Using Deep Learning tool. Please try that tool and let us know how it goes.
PriyankaTuteja
Yann-EricBoyeau
Hi @PriyankaTuteja , it works now. Thank you
