Where does Drone2Map output Contour SHP files
771
09-29-2017 07:29 AM
KenLucas
I set up the Processing - 2D products window as follows:
checked on  create contours
output format= SHP
contour settings-  base=0  elev interval-10
I executed the process and, after some hours of crunching, it completed, but I can't find the contour SHP file anywhere. Where's the default output location?
JamesTaylor3
The contours should be in C:\Users\<user>\Documents\Drone2Map Projects\<project>\products\2D\Contours
KenLucas
Thanks for your reply James. After a lot of trial & error, since I could find no you tube, ESRI online help, or mention within one of the few ESRI online courses:
one sets up either rapid or 2D products to process. In the set up insure that the DTM, DSM, & Contour boxes are checked on - a contour shp file is produced and appears in a new folder within the products folder [the shp file is likely stored in the path specified by James]
I couldn't produce contours into an existing products folder; had to process from scratch
Ken
