Weighted Overlay Service using Esri Landscape Layers
325
07-20-2017 07:42 AM
KyleBalke__GISP
Occasional Contributor III
Does anyone know if it is possible to publish a weighted overlay service using existing Esri Landscape Layers.  I can create a Raster Mosaic using Esri Image Services but when I try to publish to Server I receive an error that "the mosaic dataset item references files that are inaccessible"...is there anyway to allow Server to access these services?
Best,
Kyle
JamalNUMAN
Esteemed Contributor
I got the same error (the mosaic dataset item references files that are inaccessible) despite the fact that all the content of the mosaic are referenced with their UNC.
Jamal Numan
VinayViswambharan
1 of 2 problems:
  1. You've shared the mosaic dataset by reference and the server cant see the path.
  2. Or – whats quite likely the issues is the image paths are broken. Can you navigate to the location in the screenshot and see if you can load those files? The folder connection in his screenshots do not show any unc paths, but the analyzer shows UNC paths (in your screenshot). So something is suspect. You probably connected to a unc path and are trying to publish a mosaic dataset which has an absolute path, which is causing the error it looks like.
In your scenario, I would analyze the mosaic dataset before publishing, to ensure the mosaic dataset is clean. Then we can see if it’s a server issue (server doesn’t have permissions to the mosaic dataset/datasets) as step 2
Also based on the error code in the screenshot - see this - https://pro.arcgis.com/en/pro-app/help/sharing/analyzer-warning-messages/24016-mosaic-dataset-contai...
For all MD analyzer errors – see https://pro.arcgis.com/en/pro-app/help/data/imagery/mosaic-dataset-analyzer-error-70113.htm
JamalNUMAN
Thank you Vinay for the input.
This issue is promptly followed by Robert LeClair in other post here:
ArcGIS Pro 2.5: “analyze mosaic dataset” tool ends up with “references files are inaccessible” error...
Jamal Numan
